Moser 12 w/ Eaton posi...synthetic or non?
Old 04-11-2004, 11:11 AM
cobrakillerta's Avatar
Default Moser 12 w/ Eaton posi...synthetic or non?
So i'm going to have my gears swapped out in my Moser 12 Bolt which has the heavy duty Eaton posi...i ordered 3qts. of Redline fluid from Thunder when i ordered the gears
While on the phone with Thunder, i inquired about it and they said it's al they use
What does everyone think?
Redline? or Normal non-synthetic rear fluid?
What about during breaking in the gears?
Thanks!
Old 04-11-2004, 05:25 PM
NastySSoo's Avatar
Moser says non-synthetic only. Thats all I can tell you. Someone on another post said strange says non-syn. also.
Old 04-12-2004, 05:39 AM
Hardtop's Avatar
Strange and Eaton say non- synthetic gear lube.
Bruce
Old 04-12-2004, 10:51 AM
NHRATA01's Avatar
I've also been told non-synth only.
Also on a side note, I've only had my rear 6 days, but does anyone else's make clunks going around sharp turns? Someone told me it was the Eaton HD locking and unlocking? Sorry to interrupt...
Old 04-12-2004, 05:29 PM
NastySSoo's Avatar
Are you sure they put limited slip additve in it? If not get it ASAP!
Old 04-12-2004, 07:12 PM
MikeB.RamAir's Avatar
mine does that clunking noise and they said the same thing as they told you! I only put 1 bottle of LSD add. I have heard you need to add 2 bottles of the LSD additive, not one like the stock rear, but use non-syn. fluid just think void warrenty!!
Old 04-13-2004, 08:12 AM
NHRATA01's Avatar
Whatever is in it I think is what Moser put in it when they sent it. Though now that I think about it, its whatever Eastside put in there. Hmm, I'm probably going to have to go buy some of the friction modifier.
Old 04-13-2004, 02:15 PM
Hardtop's Avatar
The rears get sent with no oil in them.
Bruce
Old 04-17-2004, 03:50 PM
z-ya's Avatar
I spoke to the rep at eaton powertrain he recomended non synthetic for their posi unit
for maximum clutch performance.He said they had tested synthetic and that it would not hurt the posi unit,but the clutch pack performance will not be optimum.I used richmond gl6 synthetic in mine since I was having cronic gear failures and noticed no
loss in posi performance.
