Changing U-Joint
Old 11-04-2012, 05:52 PM
Mista Blazer's Avatar
Default Changing U-Joint
Changing the U- joint on my 98' TA
got the shaft removed, but can not get the bearings out. we even broke our new vice... can i use heat to heat up that area? what can i do, i need this done asap!
Old 11-04-2012, 05:57 PM
lees02WS6's Avatar
Aluminum shaft or steel? I always use a gear puller to push the u-joint through.
Old 11-04-2012, 06:01 PM
Its the Aluminum stock shaft.
I ought to post that picture of that vice. it destroyed it lol
What do you guys think of using a torch on this aluminum shaft to get the bearings out? Or would it be a better idea to use dry ice to contract it? Or third option, shall I just have it taken to a shop and have them press in my new bearings so all I have to do is drop the shaft back in?
Old 11-04-2012, 09:40 PM
Buford17's Avatar
I did this not even 2 days ago.
If you look closely youll see tiny pins sticking out of the sides of the shaft, thats a stupid nylon/plastic that was injected into it to act as a C clip to hold the U joint in. Youll have to torch it to get it out before you get the U joint out like this:
http://youtu.be/8_VIYxEA3fg
Then you can get the U join out and in the driveshaft using a press OR with a hammer and socket just like this:
http://youtu.be/rOEdul7nscY
That should be all you need. And your new U joint probly comes with C clips to put it too. There you go!
Old 11-04-2012, 09:48 PM
So its safe to take a torch to these aluminum shafts? if so i will pick up a torch tomorrow
Old 11-04-2012, 10:08 PM
01ssreda4's Avatar
The aluminum dissipates the heat really well. It's hard to get it hot enough. Mid shaft will be warm when you're done.
Old 11-04-2012, 10:12 PM
Buford17's Avatar
Yup it is. I was a bit skeptical at first too but it does take a little time to get it hot enough. You can use any propane torch lowes sells maybe even walmart sells.
Quick Reply: Changing U-Joint
