9" questions.... changing carriers and gears.
Old 11-10-2012, 08:38 AM
VandykeT/A's Avatar
Default 9" questions.... changing carriers and gears.
I've got a MWC 9" with the billet clutch posi and 4.10s. I've been considering getting another carrier set up to use at the track. Now my questions, will any 9" carrier from any vehicle work? My uncles have some 69-70 mustangs I could get a carrier from. I plan on buying a spool and gears so the actual housing/carrier will be the only thing I'll need. Will it work?
Old 11-11-2012, 02:39 AM
bww3588's Avatar
As long as the axle spline count in the same i don't see why not. Your ABS and stuff might not work properly tho.
Quick Reply: 9" questions.... changing carriers and gears.
