speeometer acting crazy
Old 11-11-2012, 10:12 AM
trazz's Avatar
Default speeometer acting crazy
i put 373 gears in my 98 camaro and had the computer set for gear swap and now at 85 mph the speedometer starts going backwards and at the end of the qtr mile the car bogged and check engine light came on i had that checked and it had a o2sensor and anti lock brake code can anyone help me out thanks
Old 11-11-2012, 08:15 PM
therabidweasel's Avatar
Speed is sensed at the trans, abs is at the diff (3 channel) or at the wheels if you have tcs (4 channel). Weird problem though.
Old 11-11-2012, 09:35 PM
trazz's Avatar
Thanks. Any ideas on correcting the problem
Old 11-12-2012, 05:27 AM
You've given far too little info. Is the car 3 or 4 channel, have you done anything to see if it actually is an 02? What was done in the computer.
To me it sounds electrical or computer related (i can't help at all with that), but the bogging could be due to killing an 02. I have had them die on hard throttle before.
Old 11-12-2012, 10:05 PM
trazz's Avatar
It's a 3 channel an I had a frost tune and then when I changed the gear I had a local shop set computer for gear change the only thing I know about the o2 is that it came up when I had it scanned it throwed a code.thanks
Quick Reply: speeometer acting crazy
