moser 12 bolt reluctor ring not lining up with ABS sensor
Old 04-13-2004, 08:38 PM
7 Second Club
NicD's Avatar
Default moser 12 bolt reluctor ring not lining up with ABS sensor
OK, problem has been like this ever since I bought the rear end used. The ABS never worked so I pulled the cover off and look what I found. Why does the reluctor on the posi unit not line up with the ABS sensor. The gears have a perfect wear pattern and are set correctly. WTF?
Old 04-14-2004, 10:04 AM
7 Second Club
NicD's Avatar
Any ideas? Ring gear possibly broken off before and rewelded back in the wrong spot?
Old 04-15-2004, 01:34 PM
slp223's Avatar
just a possibility but it could be the sensor was set up for a 3 series carrier and that is a 4 series carrier. what gear ratio do you have? the left side of a 4 series wider then a 3 that would cause the carrier to set farter to the passenger side. here is a link that might that shows the diffrence. http://www.strangeengineering.net/catalog/21.html
Quick Reply: moser 12 bolt reluctor ring not lining up with ABS sensor
