How Do I Center My Rear End?
Anyone by chance know how to center the rear end? I've got a hotchkis double adjustable panhard bar but I personally don't know how to move the rear end from right(passenger side) to left(driver side). Oh ya something I probably forgot to mention.... I'm lowered. Is this a big deal? I'm on some Ebach springs but idk how low they are. Everyone says its really low. Look at my pics and let me know if it's too low or what OTHER mods I might have to do to compensate the lowering kit. I'm needing to do this to fit some OEC ZR-1s w/a 315/35zr17 555R.
Thanks
Thanks
IMO, the easiest way is to back the car up on a set of ramps, leave car in gear and set parking brake. Then loosen both Jam-nuts on you phb and rotate the phb to make it longer until the driverside tire is a little bit closer to the fender then the passenger side is (about 1/8"). Now put some loctite on the threads behind the jam-nut, thread the jam-nuts over the loctite and tighten down the jam-nuts really good!
Your done!
If you haven't done so already get the fender lips rolled so you don't have to worry about ever cutting the tire side walls.
You'll also want to do the BFH mod on the inner wheel well. and probably clearance the rear bumpstops & mounts.
Your done!
Your done!
Your done!
Thanks
It's not on a drive on lift but, should i still go ahead and attempt to center it?
AAHHHH........ I see...Alright well ill just lower the car without the wheels on with a jack underneath the pumpkin once its done being worked on? Yes???
