Changing gear oil, Which kind and How much?
Old 04-15-2004, 03:23 PM
UB2SLO's Avatar
Default Changing gear oil, Which kind and How much?
My 98 Z28 just turned over 100K and I know its time to change the gear oil, The rear end is still stock, If heard Royal Purple is good but what weight and how much do I use, and do they make the posi additive?
Thanks
Old 04-15-2004, 03:52 PM
Gary Z's Avatar
Capacity is 3.5 pints so you need to purchase 2 quarts of any synthetic 75W-90.
Old 04-15-2004, 11:36 PM
Sudz's Avatar
Depends on your differential if you have the auburn then dont get a synthetic.. get regular differential fluid 75w90, and 1 bottle of genuine GM limited slip additive. If you have the torsen differential use a synthetic.
I have the auburn so i used valvoline 80w90, and a bottle of gm limited slip additive and it works great.
