amsoil gear oil
Old 02-07-2013, 11:03 AM
justin hover's Avatar
Default amsoil gear oil
Does amsoil 75-90 require adding limited slip additive?
Old 02-07-2013, 06:32 PM
therabidweasel's Avatar
If your using synthetic I assume you have a ZT not a clutch type eg auburn...if thats the case, you dont need the additive anyway.
Old 02-07-2013, 09:52 PM
Just my 10bolt. I didn't think you needed to, but I've read some guys do it anyway with synthetic amsoil.
Old 02-15-2013, 12:49 PM
mrhtl's Avatar
does switching to synthetic eliminate the need for the limited slip additive on the stock rearend?
Old 02-15-2013, 09:46 PM
joecar's Avatar
Torsen diff does not require LS additive, but is ok to use.
Clutch diff requires LS additive.
Most synthetic gear lube says "LS" on the bottle, this means the LS additive is already mixed in.
Quick Reply: amsoil gear oil
