View Poll Results: Which Gears?
4.30s
9
64.29%
4.10s
5
35.71%
Voters: 14. You may not vote on this poll
4.11s or 4.30s
4.11s or 4.30s
So I got my new set up that's going to be in soon. I got a Tick Performance Polluter 242/244 112 LSA, ported 243 heads, 90mm/90mm, full bolt ons, & 100 dry shot which I'm thinking about converting to a wet shot & maybe doing 150 shot. Either way I'm wondering what would you guys recommend? I'm a M6 & got 15x10 RaceStars along with some M/T 275/60R15 ET Street Radial Pro coming in the mail. I think the 4.30s would be more aggressive for NA & the cam. But for spray maybe the 4.11s would be a better route in the 1/4?
Let me know your opinions
I voted 4.30 with the 28s. A move from your current 3.89s to 4.10 isn't much.
These combos equal about the same overall ratio:
4.10 with 26" tire
4.30 with 27"
4.56 with 28".
At your old 351 rwhp 4.30s would be a good gear, how much HP are you expecting with the new setup? NA setups like more gear and a larger dia tire with a bigger contact patch and more sidewall will hook better than the smaller dia tires.
4.10 with 26" tire
4.30 with 27"
4.56 with 28".
4.10 with 26" tire
4.30 with 27"
4.56 with 28".
4.10 with 26" tire
4.30 with 27"
4.56 with 28".
What RPM do you plan on shifting at? My buddy shifts at 7200 with his T-Rex setup and his 4.30s are nice with a 26" tall tire. With a 150 shot they would definitely be too short, but if you went to a 28" tall tire for the bottle, they would probably work great.
EDIT: I am assuming that is your car in your sig, that thing looks SO NASTY! Nice car.
But make sure to vote picture of on the month!
https://ls1tech.com/forums/multimedi...ry-2013-a.html
Lol ight guess Ill go that route. Whats your set up?
Yeah I would go with at least 4.30s. On the motor it won't be as peppy as it could be but will go pretty good. I would do 4.30s if I were in your shoes, unless you only plan on spraying here and there, then maybe 4.56's. I would NOT run 4.11s though. Depending on your head/intake setup, you may want to shift higher though. 7000RPM is really not that much, especially for a big cam. Thru an LS6 intake my buddies T-Rex setup peaked at 6900, and shifting about 300RPM after your peak is right around your best bet. If you have not already, I would get some Katech rod bolts.
If you're going to spin it to 7000 then go at least 4.30 with a 28" tire. How fast do you plan on going in the 1/4 on the jug? That will dictate how much gear you can run. I run 4.33's in my car and it's perfect on the hose but it needs more gear on motor.
Also if you have dedicated track wheels/tires and haven't bought your radials yet, I'd highly advise going with a bias ply tire like an et street or hoosier qtp instead. Radials don't get along with clutch cars very well if you're going to want to launch it hard.
I think I'm going to get my set up installed then take it to the track & see where my car stands with the 3.89 gears I got now. Then Ill decide if I wanna do 4.11s or 4.30s
