9 inch leaking....
Old 02-21-2013, 03:44 PM
Chrishbsbll's Avatar
Default 9 inch leaking....
Just got my new 9 inch under the car and the hogs head has sealed where the gasket meets it and the housing. However, I have a slow leak at the bottom stud of the hogs head. It is coming through the hogs head hole and dripping out? Anyone else have this problem? What is a permanent fix?
Old 02-22-2013, 06:11 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Do you mean it is dripping from one of the studs that secure the center section to the housing? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 02-22-2013, 09:34 PM
therabidweasel's Avatar
Permatex ultra black in the squeeze cheese can, gasket goes in the trash. Better it leak from there than the damn axle seals.
"Hogs head" is new to me but I like it way better than center section or chunk. Seriously, its perfect. Exactly what it looks like.
Old 02-24-2013, 07:24 PM
jimmyducati's Avatar
you have to seal the center section and all the bolts that hold it in, I ran a bead of black rtv around all the studs, you really cant over do it on the rtv in my opinion.
and I agree, the gasket goes directly in the garbage!
Old 03-07-2013, 08:17 PM
shepss217's Avatar
hogs head? lmao thats hilarous, ditch the paper gasket and just use rtv on the inside of all the studs all the way around
Old 03-12-2013, 05:10 PM
Yes it is the bottom stud coming through the housing that secures the hogs head down. I used rtv but apparently not enough.
Old 09-02-2013, 09:30 PM
2000Phoenix's Avatar
Mine has a small leak at the bottom stud of the center section as well. Noticed it before we painted it. Cleaned it up and painted it. 2 weeks later small drips again coming from the same area. Is this common ? The thing is brand new. Is there something my mechanic should have done during the install?
Quick Reply: 9 inch leaking....
