sealant on moser 9" axle bearing?
See this:
https://ls1tech.com/forums/17025759-post15.html
Also, with NON-C-CLIP rear ends, and WITH SEALED bearings which I believe you have, you actually DO NOT WANT TO FILL THE REAR END UP to where it is coming out of the FRONT 9/16ths allen key (or whatever size it is at the front of the pumpkin).
you want it about 1/2 and inch to an 1 inch BELOW the hole.
you can also order seals from a company called Seals-it, here are a few pictures of their seals. they are installed where the axle tube meets the pumpkin and seal completely around the axle itself.
Pictures here:
I feel that the answer to the oil coming out of the axle tubes is due to people over filling them, as per MOSER instructions it simply states fill the pumpkin until it comes out of the front fill hole. HOWEVER, this is not necessary, as with it that FULL, fluid is basically just at the axle tube area and likely creeping down the axle tube without you even moving the car. Sealed bearings do not need lubrication, in the C-clipped rears they use bearings that are NOT sealed and require this lubrication.
So with installing these inner seals from Seals-It, and not filling the rear up all the way that will for certain stop the leaking. I however feel from my experience with all my BS with MOSER that simply leaving it 1/2" or 1" below that front hole will be significant enough to not leak anymore. However, being I don't want to deal with this crap anymore I'm taking all the steps I can to ensure no more leaks.
Pictures here:
i don't have the bearings with the o rings like yours, and i just used rtv around the inside of the axle housing, then i bought some inner axle seals from autozone part#51098 that your put inside of the axle tube and hasn't leaked a drop so far
