Strange Engineering Rear End Whining / Rubbing Sound
I replaced the blown seals and bearings in my Strange 12-bolt before this winter. However, now there is a whine/rubbing noise that I hear when I go around turns? It kinda sounds like the rubber from the tire is rubbing the fender, but this is not the problem, just what it sounds like.
Anyone have any ideas on what this could be? Maybe a bad bearing?
-Bryan
-Bryan
Originally Posted by SilverGhost
is the rearend properly centered? is the tq arm pinion angle correct?
if you have adjustable LCA's are both sides even?
Those are things I'd check before digging back into the rear itself.
-Bryan
