How to rearend removal?
Old 04-01-2013, 04:10 PM
TXCatfish's Avatar
Default How to rearend removal?
Anyone know of a step by step w/ pics how to remove rearend? So far I have brakes pulled, diff cover off, rear caps off, retaining bolt and caps off, and drive shaft dropped. Do I pull the rear yoke and just pull axles out? Also I didn't see any c clips, are they hard to see??
Old 04-01-2013, 04:17 PM
Guitar's Avatar
Are you trying to remove the rear end from the car or disassemble it?
Old 04-01-2013, 04:19 PM
TXCatfish's Avatar
Just disassemble.
Old 04-01-2013, 06:18 PM
1981TA's Avatar
you might be best served by removing the entire rear end. It sounds like you're attempting a rebuild, which I wouldn't do while its in the car. That's a royal pain.
Old 04-01-2013, 09:48 PM
therabidweasel's Avatar
If rebuilding def pull the whole thing.
If torsen rear you need to remove the paddle, if auburn a screw holds the pin in...After removal of pin or paddle you need a magnet to fish out the c clips. Then the axles pull right out. Only thing is if you have a 4ch tcs rear you need to remove the wheel speed sensors so you can push the axles toward the center a bit and then fish out the c clips.
Old 04-02-2013, 09:49 AM
TXCatfish's Avatar
The wheel speed sensors were in my way. Got the clips out and spent a good 10-15 mins trying to pry it out. I hope it all goes back in as easy to take out!
Old 04-02-2013, 11:18 AM
TXCatfish's Avatar
On the paddle does it only go in one way or a certain way? Just realized I didn't pay attention how I took it out.
Quick Reply: How to rearend removal?
