posi unit change question
Old 04-02-2013, 03:45 PM
2000 TA owner's Avatar
Default posi unit change question
thinking of changing just the posi am I thinking right that the pinion would not have to be reset being that pinion depth was set off center of the carrier bearings the gears are relatively new would like to reuse them just reshim the carrier to the right backlash am I correct thinking this way any help would be appreciated
Old 04-02-2013, 06:23 PM
FirstYrLS1Z's Avatar
Yes,correct.
You didn't state why you want to change the carrier/posi.
a pattern worn into the gearset is difficult to re-establish. Could end up noisier. Measure your current lash to use as starting point.
Old 04-03-2013, 10:01 AM
its the stock rear and starting to make noise while turning the gears installed have less than 2000 miles them not sure whats wrong have to look inside but if its the posi unit Ill will prolly just purchase a new unit and install it myself I know how to install one just never actually did it by myself
Old 04-04-2013, 01:39 AM
01ssreda4's Avatar
When I've swapped just posi units it really didn't require any re-shimming. I've always checked them but ended up running as is.
Old 04-04-2013, 08:39 AM
TXCatfish's Avatar
Just swapped my rearend this week. Had the same problem, tore up the spider gear.
Old 04-05-2013, 09:17 AM
what did you do
Old 04-06-2013, 04:35 PM
mthake's Avatar
I think I'm having he same problems....
Quick Reply: posi unit change question
