Aftermarket torque arm
The top bolt on the clam that holds the front torque arm bushing is stripped. I want to replace the stock torque arm setup with a aftermarket one before I have any more problems.
I however want to replace the rearned with a 9Inch in a years time hopefully.
Do the aftermarket rears bolt up with the aftermarket torque arms?
Yes you can buy a aftermarket torque arm now and it will bolt up to your 9" as long as you get a 9" housing for that style arm.
I had a UMI arm and went to a 9" from QP and it worked great. If you want to go a fab 9 style later then I would wait as they come with a arm thats a different style.
