Moser M9 35 splines guys here
I was wondering when you guys got your setups from Moser did you get the sealed bearings with or without the O ring seal around the bearing. I got a slight leak from the driver side and before I pull everything I just wanted to have everything bought and ready to go back in. If you did get the bearings with O-rings can you still put an axle tube seal in or will it interfere with the bearing at all?
Thanks Jason
Thanks Jason
1 Post
Yes on with o-ring and yes on seal. Seal sits further into the axle tube. Still add a finger-wipe of clear SILICON at the seat for the bearing. Let it dry (concave all the way around).
