12bolt and brakes
12bolt and brakes
will my cruise control, ABS, and traction control still work with the 12bolt? I will be upgrading the calipers and rotors as well when I do othe swap. is a new driveshaft needed?
Stock driveshaft usually works, if you order the correct abs setup on the rear it will work fine. If you are planning on upgrading calipers and they use a different caliper mount then stock (the part that bolts to the rear end) I would probably hold off until you had them since the bearings will have to be removed to swap the brackets because they are pressed on. Unless you dont get c-clip eliminators..
