Gear Wear Analysis?
Gear Wear Analysis?
So I've got a MWC fab9 that suddenly started making a lot of gear noise just after the 500 mile break in period (went from a lil noise here and there to constant over 30 when not coasting), and MWC advised me to pull the pinion out and get some pictures of the wear pattern on the gears and hopefully track down the root cause of the sudden noise. I'm going to be pulling the center section most likely, but any ideas what to look for? I sent these pics to MWC to see what they have to say, but I figured I'd put them up here as well.
Well, it looks like these gears were/are defective. MWC says the ring gear is too worn, but the depth/lash pattern look correct. Gonna swap in some new gears, will be my first time setting them up so if anybody reading this has some good how to links, they would be much appreciated!
Those gears look like they've had some abrasive material in the lube.
Here's what I used:
http://www.7173mustangs.com/thread-h...-a-ford-9-inch
http://www.7173mustangs.com/thread-h...-9-inch-part-2
The only thing I did differently (which may not apply in your case) is the setting of the clutch preload. I followed the Tom's Differential vids on YouTube instead of measuring, although I ended up with the same shims either way. I also got help from www.hotrodders.com in the trans and diff section...
HTH,
Here's what I used:
HTH,
Thanks for the links, much appreciated. This is the gear oil I used http://www.oreillyauto.com/site/c/de...2367&ppt=C1985
No, they are doing the labor free of charge. Im paying for new gears and shims for re set up. They will send the bad gears in to Yukon to determine if they were defective, and if they were I will get refunded for the gears. It sucks but I cant blame Eric at MWC for any of it, if anything he went out of his way to make it right for me!
