What do we have here: 31 Spline 9" Stuff
Factory 4-pin traction lock. Before selling it, you might want to pull it apart and see if there's "daylight" showing between the ring gear bolt bosses and the clutch tab pockets. If so, it's pretty much a paperweight. Mine was and I ended up tossing it out and going with a billet unit from QP.
Well... That's the Ford version of a "posi". Ford 9's had an "Equalok" until the early 70's, then Tracklok from then thru '86 when it the 9" was discontinued. Being a 4-pin is good, but only if the case isn't overbored. Scroll almost to the bottom here to see what a case looks like when it comes apart.
