Should I switch to 3.90s?
Old 06-14-2013, 07:59 AM
Sail Hatan's Avatar
Default Should I switch to 3.90s?
Entertaining the idea of a gear swap. I currently have a 3800 stall, 231/235 cam, and stock 3.23 gears. I wanted to buy 3.90s when I get a 9 inch, but Id like to try them first in my 10 bolt. see if I'd want to remain with 3.90s when I switch rears. am I going to notice a difference? pros? cons? I dont drive it much, and dont beat on it too often. thoughts? what gears are people running in autos?
Old 06-14-2013, 12:12 PM
FirstYrLS1Z's Avatar
3.73s' are the most popular setup,a few of the brave run 4.10s',I ran 4.56s' for 4 years.3.23s' and 3.42s' are good with a stall with 3.73s' most popular for a compromise between top end and acceleration.
Old 06-14-2013, 12:51 PM
Sail Hatan's Avatar
will i notice a difference? i was told 3.90s are a better gear. a little stronger.
Old 06-14-2013, 01:06 PM
marksboy7's Avatar
What is your main focus for the car? Racing at the strip? Or daily driver?
Old 06-14-2013, 02:57 PM
Sail Hatan's Avatar
Neither. I drive it a few times on the weekend. I most certainly don't daily drive it. Cruise on the weekend, some spirited driving. I just want fast acceleration
Old 06-14-2013, 03:11 PM
marksboy7's Avatar
I'd go 3.90's then. You could go even go lower if you don't drive it much. That's what I'm switching to also. I'm more focused on racing though. You should be able to tell a good difference going from 3.23 to 3.90.
Old 06-17-2013, 06:07 AM
Sail Hatan's Avatar
Ok that's good. I feel like any lower, like 4.10s is too much.
Old 06-18-2013, 09:53 PM
Midnight02's Avatar
As noted above, you'll feel a noticeable difference between the 3.23's and the 3.90's.
Old 06-20-2013, 04:50 AM
nj02z's Avatar
I have 3:73 now with a 4000 stall converter which drives fine.I am putting in a 9 in. and going to 3:90.My car will cruise around 2400 at 65mph with 3:73 and I cant imagine 3:90 gears will be that much different.
Old 06-20-2013, 05:50 AM
50 more rpm per 1000.
2000rpm now,2100rpm future.
Old 06-20-2013, 06:08 AM
Sail Hatan's Avatar
That doesn't seem too bad. From 3.23 to 3.90 will be a bit higher.
Old 06-20-2013, 08:59 PM
Blackpanther99's Avatar
Youll be fine.
Old 06-20-2013, 09:03 PM
ramair 1's Avatar
loving my 390 id do it again
Old 06-24-2013, 06:03 PM
KingPin1094's Avatar
From what i've read on a previous thread is that switching from a 3.23 to a 3.90, it will make it feel like the car has 17% more torque. Im not sure if thats true and i cant back up that information, but thats what i heard.
Old 06-26-2013, 12:06 AM
mikes87ss's Avatar
I just had 3.90 gears put in my 02 TA m6.Still breaking them in ,have'nt really beat on it ,but can definately tell the difference.
Quick Reply: Should I switch to 3.90s?
