9"..Use Gasket or No?
Old 04-28-2004, 09:42 AM
Motorboater
SilverGhost's Avatar
Default 9"..Use Gasket or No?
I'm putting my 9" back together this week after the spool gets setup in the centesection..before the damn rearend always leaked alot.
When I first put it together I used black rtv and the provided gasket to put the pumpkin in the housing and I noticed that it didn't take real long for that gasket to get eaten away and become useless and it started leaking alot.
I had someone say i should put it back together minus the gasket and it wouldn't leak..anyone try this or something else in particular that has kept their 9" from leaking?
thanks in advance..
Old 04-28-2004, 09:49 AM
Fireball's Avatar
I've done it both ways and never had leak problems there. I used RTV even when the gasket was used
Old 04-28-2004, 01:13 PM
LOnSLO's Avatar
I have a rubberized gasket that I use over and over again with no silicone, and no leaks. I can't remember who makes it though, sorry.
Old 04-28-2004, 01:15 PM
Motorboater
ok, i think i'm gonna try no gasket and just rtv this time. like i said i used rtv AND the gasket last time and that just lead to constant leaking problems
Motorboater
oh and Fireball which color/type of RTV do you use that works for you
Old 04-28-2004, 01:36 PM
LOnSLO's Avatar
I used to use the orange high temp stuff. Works great.
Old 04-28-2004, 02:15 PM
Motorboater
sweet thanks man
Old 04-28-2004, 09:10 PM
wrencher
wrencher's Avatar
I like to use permatex "the right stuff", it's not cheap but it works.
Clean the mating surfaces with brake clean, get totally dry & goop it up let it tack-up for 5 min. & slap it together.
Old 04-29-2004, 10:13 AM
Motorboater
i usually use permatex for everything, so the high temp one would be best? there are several permatex variety if i'm recalling corretcly.
that's what i ddi the first time, lack it tack up a bit using the black stuff with the gasket. def gonna try no gasket this time.
Old 04-29-2004, 11:40 AM
Fireball's Avatar
I used the black RTV I think
Old 04-30-2004, 11:40 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
<----black rtv, no gasket
Old 04-30-2004, 12:30 PM
kp
kp's Avatar
ultra black works well. I havent used a gasket on a 9" since silicone came around.
Old 04-30-2004, 01:29 PM
Motorboater
sweet, thanks for the input, the more the better..gotta see what works for others as i don't want any damn leaks this time, always making a mess outts the garage and driveway and stuff.
guess i'll go with that permatex ultra black, pretty sure that's what i used last time with the gasket..i bet it was the gasket the f'd everything up
