How much longer might my rear have (pic included)
Old 07-01-2013, 06:08 AM
FSUNole17's Avatar
Default How much longer might my rear have (pic included)
So I had a dealership take off my cover and took the attached picture. Tech said he found a bunch of shavings stuck to the magnet and that the bearings were being ground away. He quoted me between $1,200 and $2,400 to fix. For that, I'd rather get a brand new 9". I am just wanting to know if anyone can tell from that picture if it is just a matter of days or I got some time, and did that tech shoot me straight?
Old 07-01-2013, 06:10 AM
FSUNole17's Avatar
Here's the pic
Attached Thumbnails How much longer might my rear have (pic included)-20130625_090218.jpg
Old 07-01-2013, 06:14 AM
SSellers's Avatar
If it just looks like fur it's normal. Knowing how many miles it has on it since the last service would help know how "normal".
That's one wide *** quote. "It'll run around this much. Or twice that."
Old 07-01-2013, 08:16 AM
wrd1972's Avatar
Tech is trying to screw ya'.
That metallic fur is normal for a 10 bolt and means the gears have properly worn in like they should.
Old 07-01-2013, 08:56 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
^^^ correct. These guys are just trying to sell you up. That is normal buildup of any rearend with a magnet installed to catch the shavings, and unless the rear has excessive noise or leaks to look further into then tell them to just put it back together.
Old 07-01-2013, 09:29 AM
FSUNole17's Avatar
In my case, the rear does whine pretty bad. It is so noticeable on the highway in 6th gear cruising that I have to really raise my voice just to carry on a conversation with a passenger. If this is "normal" noise, then GM really sucks at quality.
Old 07-01-2013, 09:34 AM
SSellers's Avatar
Mileage on rear and previous service mileage?
Old 07-01-2013, 12:19 PM
FSUNole17's Avatar
60k miles on the rear and it was taken in shortly after purchase to have the ring pinion reset (exact service escapes me but I have paperwork at home). Either way, nothing has been done to it in a while. It hasn't been beat on because I took it out and put a 9" in when I raced and when the racing phase went away, put this back on.
Old 07-01-2013, 02:34 PM
sicksspeed's Avatar
You have noise # 1, #2 if I saw that much metal I would say you got a problem. I worked at gm dealer for a long time like 25 years. I can see a dealer charging 8 hours to overhaul rear times $100 /hr. The one thing is with cover of the only question I would have is wether the axles are bad. I don't know what they cost. So overhaul with parts 1200 at dealer, yes. Plus axles 2400 sounds high and probably don't need. Life of axle, grab yoke of pinion and push up and down. Moves? Game over. Not moving? Some time. Other than that can't tell without seeing. P.s. I bet the pinion bearings are gone. If noise changes on and off gas then good sign those bearings are done.
Old 07-01-2013, 02:41 PM
FSUNole17's Avatar
Noise does change when on/off gas
Old 07-01-2013, 03:41 PM
sicksspeed's Avatar
There you go, bets are on pinion bearings. But I am sure the person making the repair will want to do all the bearings as I would. Yes you should be able to get the job done for less but you need to find someone who does good work. If you wish to continue with the dealer have them explain the varying price better. If it hinges on axles have them POP them out first. And go from there.
Old 07-01-2013, 03:44 PM
sicksspeed's Avatar
Also you almost definetly do not need ring and pinion. If they are not chipped the worst you might get is slight noise but I Dout you will notice.
Old 07-06-2013, 04:39 PM
Bobatsuperior's Avatar
The "fur" looks normal to me
Old 07-06-2013, 10:49 PM
01ssreda4's Avatar
That looks a little worse then normal IMO. I'm gonna agree with sicks here on this one.
Old 07-07-2013, 09:57 AM
Andrew1989's Avatar
It's hard to say. My rear has been making noise for 80000 miles. They're such pos that it isn't even worth my time to fix it. If I ever had to remove it to work on it I wouldn't insult my car by putting it back in. I'd just lt it rock until it tanks then fix it the correct way by throwing it away and upgrading.
Old 07-07-2013, 08:11 PM
00ssmg's Avatar
this looks a like a little too much metal for me. If the rear is making so much noise that you cant have a conversation at highway speed you should probably pull it apart and check. I would say that this wear is normal except you state that there is only 60 thousand miles on it. that would look like normal wear for probably double that amount of miles. Check the pinion seals and axle seals to see if they are leaking. if one of them are I would bet that there is a bad bearing behind it. Hope this helps.
Quick Reply: How much longer might my rear have (pic included)
