Highway Vibe - Pretty Sure it's the Rear
I've got a good vibration above about 65 in my 8.5" 10 bolt. It has resulted in false brinelling of the axles' outside wheel bearing races (see pic below) and backed the pinion nut off at least once.
The car is a '71 Nova with an LS and 4L80e. The rear has 3.90s and an Eaton posi unit, and is not original to the car. I'm pretty sure it has been present since I had the rear installed, though I didn't get above 60 much before swapping in the LS and 4L80e.
The engine, trans, wheels/tires, and drive shaft were replaced when I did the swap, and the drive shaft has been double-checked for balance. The driveline angle has also been double-checked, and revving the engine in neutral does not introduce a vibe.
I just had the axles out and took some photos. Does the gear pattern show anything, and what else should I be looking for? Also, I'm in Phoenix, so any recommendations for a good shop NOT on the West side would be greatly appreciated.
And the false brinelling on the axle
Im not good with patterns, but to my dumb eyes the coast side does look shallow...drive side may be a little shallow too. But, do not go by my word...I wouldnt.
Backing off the pinion nut sounds like one hell of a vibration. Have you checked the runout of the axle flanges etc? If you put it up on stands does it still vibe, if yes does it still vibe with no wheels? If it vibess with the suspension loaded and no wheels and not reving in neutral its the ds, yoke, or rear...right?
I'll double-check the u-joints and driveline angle. It's fairly easy to manipulate angles with the rear. I'm also going to get it up while on jack stands with the axle supported and unsupported to see if it affects vibration.
Pinion nut was re-torqued when they checked the drive shaft. It and the crush sleeve was reused (I know, bad...).
I checked pinion and driveline angles last week, but didn't check the driveshaft, so I'm not sure how the angles were vs. the shaft. Due to the fact that the vibe seems to go away upon acceleration, I moved the pinion upwards one full turn of the ladder bar adjusters (didn't check angle thereafter). I haven't driven it since (I get only a half-hour here and there due to the kids and my wife hating me working on the cars), but did get it up to ~65 with the frame on jack stands and the rear axle drooping. It still vibrated.
I also can't find any markings on the u-joints to sync them. I'll try to take it out on the highway tonight.
I broke down and took it to a shop near work. They found the pinion bearing bad (said it was likely due to overtightening). They said they could open it up, but that it would probably open up a can of worms, so I'm going to hold off for now.
Oh, and the driveshaft was twisted. Which is bad, but also pretty awesome?
