weight difference between detriot locker and spool?
Old 07-02-2013, 09:31 AM
mike13's Avatar
Default weight difference between detriot locker and spool?
Does anyone know the weight difference between a Detroit locker and a spool on a 9" ?
Trying to figure out how much weight I can save going to a aluminum case and a spool versus my present iron case and Detroit locker. I know the aluminum case saves about 12lbs.
Old 07-03-2013, 12:22 AM
01ssreda4's Avatar
Complete guesstimate but most posi's are 40-50lbs on the shipping label, spool probably 5-10 I would bet. Pretty big difference.
Old 07-03-2013, 07:56 AM
mike13's Avatar
ya I don't have any idea, hoping it's a big difference.
Old 07-03-2013, 07:06 PM
BOLO's Avatar
I can tell you that the lightweight pro race spool on my S60 weighed a lot less than the ring gear alone. You can't go any lighter than a spool in a race application.
Old 07-03-2013, 10:06 PM
Carl at CRP's Avatar
The Strange aluminum 9"case is 20 lbs lighter than the iron.
The 35-spline spool weighs 8.2 lbs but I'm not certain the weight of the locker.
It will cost better than $600.00 to do this not including labor, sometimes its better to put that kind of money toward HP gains. You might end up shaving more ET per dollar spent!?
Carl
Old 07-05-2013, 05:44 AM
01ssreda4's Avatar
Definitely depends on mod level. Hp starts getting expensive!!
Quick Reply: weight difference between detriot locker and spool?
