rear end help
rear end help
Im building a daily driver around 530ish horsepower at the crank I want as much as that to the wheels as possible... I was thinking of a gm corp 10 bolt because I know u can build them super strong or a for 9" but guts wise its so many options im lost where to start
LS1Tech Premium Sponsor
A4 or M6 trans? There is no corporate 10 bolt from Gm that will bolt into your car due to the torque arm mount.
A 9" ford style rearend will always be a good choice, but can get costly. You may also consider a S60 or 12 bolt rear from Strange that is full aftermarket and designed to be a direct bolt-in.
The g national 10 bolt bolts right up everything matches I have a family member with the same build and has been done already ... 4l80e is the trans thats going in I need help with gears and axles housings im ok with because thats all depending on how much I want to spend
Ok then... How did they mount a torque arm to a G-body rearend that uses triangulated 4-link suspension?
A set of 31 spline axles and a clutch type posi or a Truetrac diff unit will be good choices for the power you expect to make and the 4L80 trans combo in a street driven car.
You just answered your own question if you cant use it cut it off grand nationals had the torq arms monte carlo doesnt ..im not posting to get into a pissing match I just asked what gears and axles would be a ideal setup for what im running I have seen several ppl in the g body world with this setup get on a couple forums you will se its not as uncommon as you think
