8.8 build question
Old 08-13-2013, 09:08 PM
reinhardt02's Avatar
Default 8.8 build question
I want to throw an 8.8 in my Camaro. I have the skills and tools to do the swap, but I am ignorant to rear end setups. I want to know if you can use an 8.8 28 spline carrier w/ the Camaro axles and 9" bearing ends, eliminating the c clips.
Here is my thought. I can save the cost of having axles made. I also don't have to worry about the mismatch of the Camaro axle c clips w/ the 8.8 carrier. If the Camaro axles fail, I can get a 31 spline carrier and have custom axles made.
Will it work? Thanks guys.
Old 08-18-2013, 07:39 PM
Anyone?
Old 08-25-2013, 11:22 AM
watman02's Avatar
yes you can use a ford 28 spline carrier with gm 28 spline axels
as for 9in bearing ends???? cant help ya there pm hiltsy he'll know.
the c-clips are almost identical in size and shape so i wouldnt worry about it.
yes you can have 31 spline axels made to fit your set up but you will pay for it.
Old 08-26-2013, 05:44 PM
S10xGN's Avatar
Really? That's awesome, seeing as how the Ford axles are 1.29" diameter and the GM axles are 1.20" diameter. Not to mention the spline cut and pressure angles which I have no knowledge of...
Old 08-28-2013, 06:49 PM
cantfind2nd's Avatar
why not upgrade to an explorer 31 spline carrier? and to use 9 inch bearing ends you need new axles that allow bearings to be pressed on them.
Quick Reply: 8.8 build question
