12 bolt axle stud options?
Old 09-11-2013, 05:42 PM
DemonicZ's Avatar
Default 12 bolt axle stud options?
the available options are:
12mm x 1 1/2 (.505" knurl)
12mm X 2 1/2 (.505" knurl)
1/2" x 20 x 1 1/2" (.620" knurl)
1/2" X 20 x 3" (.620" knurl)
1/2" X 20 X 2" (screw in)
1/2 X 20 X 3" (screw in)
which should be ordered for stock axle lengths and stock brakes
what is the differences between them all.
Old 09-17-2013, 03:05 PM
LS1Tech Sponsor
Summitracing's Avatar
Received 1,121 Likes on 618 Posts
If you are using stock axles and brakes, the stock replacement wheel studs would be a 12 x 1.5 mm, with 0.505" knurl, and 1.50" long.
The other options you listed would only be used if you either want to change the thread size, or need an extended wheel stud for racing or wheel spacers. Hope this helps.
__________________
800-230-3030
www.SummitRacing.com
Quick Reply: 12 bolt axle stud options?
