what yokes fit into a moser 12 bolt?
found out why pinion seals dont work on my moser 12 bolt. seems like i have a spicer yoke that is 2 inches in diameter. Any idea on what different yoke could fit in instead or a pinion seal that would fit? Current yoke is 30 spine.
LS1Tech Sponsor
Received 1,120 Likes
It sounds like you may have the wrong differential yoke. There are a few different Moser 12-bolt yoke options that will work. Just make sure you choose the one that offers the correct u-joint option for your existing driveshaft.
Thanks! That's exactly what i did. It seems like they only had two choices that would work for my setup and the previous setup was a disaster. When it comes to your cars, NO mix and match... is the lesson learned. Now i get to say I'd like a pinion seal for a 12 bolt '70 Chevelle. Sweet.
