Changing gears...
Old 09-26-2013, 09:39 AM
67rally's Avatar
Default Changing gears...
I just did an LQ9/T56 swap in my '67 Camaro this year and love it, but I'm still running the old gear ratio in my rear. I had it dyno'd at 458/410 to the rear wheels.
The rear is a GM 12 bolt posi with 3.31's. The T56 is out of a GTO, so it has a 2.97 first gear. Everything I knew told me 10:1 was the ideal ratio and this combo gives me a 9.83:1. Also, I find the .57:1 6th gear pretty useless until you get close to triple digit speeds.
This is a not my DD, just a fun weekend/nice day car. 99% street driven. I was thinking about 3.73's or 4.10/4.11's. Looking for a nice bump in acceleration. Any real life advice is welcome. Thanks.
Old 09-26-2013, 12:48 PM
1981TA's Avatar
With the 3.73s in mine, I was cruising at 80 MPH @ 2000 RPM in 6th, with a .50 overdrive. I guessing, if you don't mind rowing the gears a bit, 4.11s will give you the kick you want, while still giving you decent highway cruise RPMs. 3.90 might be a good choice too.
Old 09-27-2013, 05:00 AM
67rally's Avatar
I think the 3.73's would be an easy swap.
I didn't even think about 3.90's. Are those 3 series carrier compatible? I know the 4.11's are a 4 series, and would need a carrier change.
Old 09-28-2013, 12:19 AM
01ssreda4's Avatar
I'd go with the highest gear available for your series carrier for simplicity reasons. What size rear tire are you running?
Old 09-28-2013, 01:06 AM
67rally's Avatar
275/40/18's on the rear.
Old 09-28-2013, 11:04 PM
01ssreda4's Avatar
Most like 4.10s, but some complain it makes the lower gears useless......I always liked it though.
Quick Reply: Changing gears...
