What Rear End for my set up?
Old 09-28-2013, 06:04 PM
1bad96camaro's Avatar
Default What Rear End for my set up?
So I have a 96 Camaro with the stock 10 bolt. I pulled the lt1 and swapped it with a gen 1 sbc, it made 444hp and 429ft lbs at 6200 rpm it nothing to crazy just a mild small block. I want a direct bolt in rear end with 410s wondering what to go with? build my 10 bolt do a 9 inch idk. The car is a weekend toy and sees the track maybe once a year. Do they make a rearend that all my breaks and everything bolts onto? Any help would be great
Old 09-28-2013, 06:29 PM
Tom94TA's Avatar
That's easy. Get a Strange S60, bolts in like stock. The base price includes billet brake mounts for LT1 brakes. If money is tight (and who's isn't) all the stock suspension components work with it and the pinion angle stays the same as stock. IMO there's nothing better. With a spool it costs like $2035.
Old 09-28-2013, 06:35 PM
where the best place to get one
Old 09-28-2013, 06:41 PM
Tom94TA's Avatar
Get in touch with Carl at Central Racing Parts (site sponsor). I bought mine from him, Carl is probably Strange's #1 S60 dealer. He knows all the ins and outs of spec'ing one of these so it meets your needs.
I can't speak highly enough of Carl.
https://ls1tech.com/forums/gears-axl...l-back-19.html
Check out this bad boy.
https://ls1tech.com/forums/17074380-post287.html
Old 09-28-2013, 06:44 PM
awesome thank you
Old 09-28-2013, 10:55 PM
01ssreda4's Avatar
I'd buy a 12 bolt, s60 is way overkill for what you're doing. Strange all the way, Carl @ CRP can fix ya up. https://ls1tech.com/forums/gears-axl...t-install.html
Quick Reply: What Rear End for my set up?
