How many running notrous on 10 bolt?
How many of you guys running nitrous on the stock 10 bolt? I just put in a nitrous plate and was going to run a 200 but just put in a 100 shot. I have not even tried it yet. I'm scared.... I heard these 10 bolts hold up better with stock gearing. ?
Just curious how many of you are running the stockers with higher HP cars.
Depends what all you have done. I have hit mine a couple times on the street but I would be afraid to hit it in 1st gear on the track. Who knows, when I finally make it to the track I probably will try it and see what happens
I have made several hundred passes on motor and 50+ passes on the 150 shot. Best 60ft I got out of it was a 1.45 on the spray. Mostly 1.5-1.6 with a soft hit in the progressive box. Unfortunately my aggressiveness finally got it Friday night.
