ford 9 inch 1350 yoke question
Old 10-07-2013, 09:05 PM
darkbluez28's Avatar
Default ford 9 inch 1350 yoke question
i ordered a 9 inch swap housing from quick performance. do i need the short 1350 yoke or the long yoke. ive read some places the short works and someother places the long works. any help is much appreciated. i will be using my stock aluminum driveshaft that uses a 3r and ill be using neapco 2-1153 3r to 1350 conversion u joint. also its an 99 z28 six speed
Old 10-07-2013, 09:31 PM
someone has to have a 9 inch swap and can tell me what there using with there stock driveshaft
Old 10-08-2013, 11:22 AM
96lt4c4's Avatar
Long 1350 style Yoke, you will need a conversion u joint to your stock drive shaft.
Old 10-08-2013, 10:39 PM
roy
roy's Avatar
You can also use a long 1330 yoke and still utilize the 3r joint with your stock shaft.
Quick Reply: ford 9 inch 1350 yoke question
