rear main cap torque specs
Old 05-04-2004, 06:56 PM
98TransamLS1's Avatar
Default rear main cap torque specs
I really need the torque specs for the 4 rear main cap bolts. I have a 98 trans am. My 3.42-4.11 swap seems to be going smoothly,and im putting everything back together, and I cant find the torque specs for the main caps. Please help!!
Old 05-04-2004, 10:05 PM
kp
kp's Avatar
here you go..
Differential Carrier Bearing Cap Bolt/Screw
75 N·m
55 lb ft
Differential Drive Pinion Gear Setting Gauge Nut
2.3 N·m
20 lb in
Differential Pinion Gear Shaft Lock Bolt/Screw
36 N·m
27 lb ft
Differential Ring Gear Bolt/Screw
120 N·m
89 lb ft
Rear Axle Housing Cover Bolt/Screw
30 N·m
22 lb ft
Rear Axle Housing Drain Plug
35 N·m
26 lb ft
Sensor Plug Mounting Bolt/Screw
10 N·m
89 lb in
Wheel Bolt
140 N·m
100 lb ft
Wheel Speed Sensor Mounting Plug
10 N·m
89 lb in
