Back braceing a Moser 9 inch
Old 10-30-2013, 02:37 PM
KilerTA's Avatar
Default Back braceing a Moser 9 inch
I recently puchased a used Moser 9inch. Id decided to install a diffrent gear set. In the process i said what heck and sand blasted it . With the intent of POR 15 and installing drain plugs. What is everyone opion of installing a back brace on a used rear end. Is it a smart idea to install on a used rear end or not?
Old 10-30-2013, 03:53 PM
user_guest3214's Avatar
I don't know about that, but if you went through all the work of blasting the housing, why not just have it powder coated for 50-75 bucks?
Old 10-30-2013, 07:51 PM
Carl at CRP's Avatar
When building a housing the last weld should be the housing ends, if it were brought to Me to add a back brace it would also have the ends cut off and re installed. Could get pricey!
Carl
Old 10-30-2013, 08:57 PM
ramairetransam's Avatar
doing a small spot on one side and then a small spot on another wouldnt work ? And not finish the whole job on the 1st try , maybe 4-5 heat ups. ?
Old 10-30-2013, 10:42 PM
cav101's Avatar
A local guy did it in his 9s mopar. I blasted painted it for him after he added the back brace. Running strong for over 5 seasons. FYI.
Old 10-30-2013, 11:06 PM
1BAD98LS1's Avatar
Kind of risky unless your very careful with your heat input while welding. Don't want to cause the axle tubes to pull, it doesn't take much heat to cause them to move. I wouldn't think its worth the risk or cost to add it.
Old 10-31-2013, 06:53 AM
You can sure try it, just take it to a chassis shop and have them check it for straightness after Your finished. For an interesting experiment have it checked before You start too.
Carl
Old 10-31-2013, 08:23 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Question
How much hp and how fast do you plan on running? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 10-31-2013, 08:49 AM
KilerTA's Avatar
PM Sent
Old 10-31-2013, 09:09 AM
LS1Tech Sponsor
PM Sent
PM replied to. Thanks. Bob
__________________
Old 10-31-2013, 09:41 AM
DEFYANT's Avatar
Eric @ Midwest Chassis states that when you buy the 9" that he offers that if you have idea that you're going to need the backbrace, add it then or forever hold your peace, I assume this is for a reason. Like someone said earlier, the tubes will pull away with VERY LITTLE heat.
Old 11-01-2013, 07:22 AM
LS1Tech Sponsor
PM Sent
Did you get in touch with Shane? Bob
__________________
Old 11-01-2013, 09:17 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
^^^ this.
If you add a brace to the housing no matter what the weld process is you WILL warp the housing.
Old 11-02-2013, 06:21 PM
KilerTA's Avatar
No its on the log list of things i need to do. Ill get back to you on what gets discussed.
Quick Reply: Back braceing a Moser 9 inch
