How durable can a 10 bolt be.. Assuming you never launch
Old 10-31-2013, 12:07 PM
1994_383_Z28's Avatar
Default How durable can a 10 bolt be.. Assuming you never launch
So this has probably been gone over a million times by now.. But I'm interested in putting 4.10s in my stock 10 bolt. Now here's the catch.
This car will see no track time. No sticky tires. Pretty much it's a street warrior. It'll see pulls from a roll, always on street tires. No launches at all.
So am I kissing my rear end goodbye.. Or could it hold up?
Old 10-31-2013, 12:28 PM
ponchjoe's Avatar
What horsepower range are we talking? What mods to engine and drivetrain?
Old 10-31-2013, 12:31 PM
wilkes02SS's Avatar
eventually, yes. But the big issue with the 10 bolt is from a dig on sticky's. Once you do that, its pretty much a grenade waiting to go boom. Mine happened to go at the track, but before I ran sticky's at the track it lasted forever(110,000mi) with some serious street time, and the majority of those miles/street time was already a built LS1. you should be fine for a long time, but eventually I personally would replace it.
Old 10-31-2013, 12:45 PM
It made 380rwhp with the stock ls1 intake, stock throttle body untuned. It now has an ls6, ported throttle body, and soon to be dyno tuned. So around 400rwhp estimated.
Stock rear, stock driveshaft with reinforced u-joints, stage 2 rebuilt t56, ls7 clutch.
Old 10-31-2013, 12:47 PM
Well I honestly don't plan to keep my car for very long. Maybe another year or two. And that's pretty much what I was thinking. That as long as I stay on street tires and don't launch.. Hopefully it would hold.
Old 10-31-2013, 01:36 PM
BrntWS6's Avatar
It'll should be fine. I ran 460 rwhp on the 10 bolt for 2 years running 315 Dr's. I also did plenty of roll racing. The only issue I had was the pinion seal kept leaking.
I did just get a 9" because I'm going to spray it eventually and didn't want to put money in the 10 bolt for gears, TA etc.
Old 10-31-2013, 03:19 PM
BKsNHRA's Avatar
380 rwhp t56 sticky tires =
Attached Thumbnails How durable can a 10 bolt be.. Assuming you never launch-1452076_757951087564377_392018345_n.jpg
Old 10-31-2013, 04:27 PM
arock24's Avatar
Granted I'm an a4, I'm running about 420rwhp through a 10 bolt. Honestly, street tires and rolls will be fine for the stock rear end. While I would definitely consider it the weakest link in the car, proper maintenance and non-abusive driving will help make the 10 bolt last. May want to consider throwing a T/A cover on there for a little additional support.
Old 11-01-2013, 02:51 AM
Burken01's Avatar
Borrowed time, and... You have to baby your car to keep it happy..
What's the point of making your car go fast if you can't drive it hard?
Old 11-01-2013, 09:14 AM
Tom94TA's Avatar
Originally Posted by burken01
what's the point of making your car go fast if you can't drive it hard?
Bingo
Old 11-01-2013, 11:57 AM
Not sure what you mean by " You have to baby your car to keep it happy.. ".. Are you saying it wouldn't hold up to roll races on street tires? I honestly don't know if it would or wouldn't.
By "driving it hard" do you mean launches? I have no intention of launching this car regardless of what rear end I have. I just drive around town, and do occasional 1st and 2nd gear pulls from a roll.
haha I'm fully aware of how fragile 10 bolts are with sticky tires.. My question is regarding street tires.
Old 11-01-2013, 12:24 PM
arock24's Avatar
I have a spirited driving style, I just choose not to launch from a dead stop all the time and keep street tires on the back for now. I may have "borrowed" time but you can have a little control of how much time that is. I'm fully expecting a lvl 2 4L60 and s60 to be my next purchase(s)..there goes $5k
Old 11-01-2013, 07:49 PM
Z28Dave's Avatar
i wouldn't plan on a turbo
Attached Thumbnails How durable can a 10 bolt be.. Assuming you never launch-316908_543618855655758_1876953894_n.jpg   How durable can a 10 bolt be.. Assuming you never launch-549794_543618825655761_748245737_n.jpg
Old 11-02-2013, 07:46 PM
DemonicZ's Avatar
I blew my bearings in my 98Z A4 with stock power at 132k miles. I had 6 passes on the strip not launching and after that it was gone. I replaced it with a stock replacement 10 bolt with 28k miles from a 99 T/A. I hope I can get another 110k miles out of her or have the funds available for a Moser 9 with wavetrac. 10 bolt is always and will remain the weakest link of the 4th gens.
Also I don't drive as hard on her anymore.
Old 11-03-2013, 06:09 PM
Blackpanther99's Avatar
Mine held up to 160k with no issues with a M6 before I ended up tearing up the car to get me a 9". Otherwise it would still be running! Never really abused it since I was still in High School and couldnt afford a new rear end.
Old 11-03-2013, 06:13 PM
HCI2000SS's Avatar
I'm making around 450 rwhp n/a, and 550 rwhp on the bottle with a M6, 4.10's, Nitto dr's, and the stock 10 bolt. No problems for me as of yet
Old 11-03-2013, 11:21 PM
S8ER95Z's Avatar
175k on mine... It has several hundred passes at the strip and some playing around. Never been on a sticky tire and I'm known to bog instead of spin while launching. Not sure how much longer it will live but so far it's been fine.
I believe I'm around 370-380rwhp (until a Dyno breaks my heart that's my guess).
Old 11-04-2013, 08:54 PM
BKsNHRA's Avatar
To answer this. My 3.73 have been in the car for nearly 8 years or so. T56 car. Always on a normal tire. It was fine as long as it was spinning. I put the tires on it and 3 passes and the ring gear was a gone LOL.. If your not on any kind of drag radial itll be fine. If you are all bets are off.
Old 11-05-2013, 12:28 PM
SladeX's Avatar
stock diff dead around 140k miles, chewed up spider gears. at 180k miles lost 2 pinion teeth. Wheel bearings showing signs of chewing into axles.
Ran drag radials and street tires, 200+ launches on track. Lots of roll racing.
Gears swapped out around 40k miles to 3.90 gears.
Will your 10 bolt last? Everyone is different with how they drive. On a camaro with less than half the power I was breaking 10 bolts every 60k miles. Auto. Street tires. Go figure.
Quick Reply: How durable can a 10 bolt be.. Assuming you never launch
