Mini ladder bars suck!!!! My new set up
Old 11-13-2013, 10:47 AM
Hulkls1's Avatar
Default Mini ladder bars suck!!!! My new set up
I put a 8.8 out of a 93 crown Vic it's 64 1/2 inches wide its not even a 1/2 shorter than the stock 10 bolt. So I put the mini ladder bars on it went to the track and it wheel hoped so bad I snapped a axle and it drives like **** . Now I got the IMaximum Motorsports Torque-arm suspension system.
For a mustang and its bad *** drives way better going to the track next weekend and see what it does
Old 11-16-2013, 08:34 PM
cantfind2nd's Avatar
Pictures?
Old 11-20-2013, 10:04 PM
LT1RAY's Avatar
Any pictures of this setup?
Old 11-21-2013, 12:04 PM
hiltsy855's Avatar
linky - It's built for Mustangs
Old 11-21-2013, 06:10 PM
LT1RAY's Avatar
Thanks Hiltsy, I had found the product but I'm curious to see how it fits an f-body.
Old 11-22-2013, 05:46 AM
hiltsy855's Avatar
Maybe just need a custom crossmember? Then how do you adjust pinion angle?
Old 11-22-2013, 11:19 AM
LT1RAY's Avatar
I believe the pinion angle is adjusted by the two bolts that mount to the housing.
Old 11-22-2013, 01:41 PM
I think that's what all the shims are for. I looked into doing this but kind of pricey.
Old 11-22-2013, 01:43 PM
But pretty sure i could duplicate it for cheap
Old 11-22-2013, 05:54 PM
hiltsy855's Avatar
^This^ - If you can find a Crown Vic or Town Car with a 31-spline carrier this would be the ideal 8.8 swap. Older cars all had 28-spline from what I've found, but some newer ones had 31-spline.
Old 11-23-2013, 10:53 AM
Could always swap an explorer 8.8 31 spline carrier into those 8.8 housings. Im pretty sure mustang 8.8 are 2 inches narrower each side. But those brackets I used are only made for 3 inch or 3.25 in axle tubes , think mustang 8.8s are 2.75
Old 11-23-2013, 04:13 PM
LT1RAY's Avatar
Had the OP send me a few pictures of his setup. This is using the standard duty MM torque arm and a 28 spline 8.8 out of a Crown Vic on a 01 Camaro.
Old 11-23-2013, 04:33 PM
Murd450's Avatar
How did he bolt up the control arms ? Is it direct bolt ?
Old 11-23-2013, 07:58 PM
Most likely welded on f body brackets.
Old 11-23-2013, 08:12 PM
Murd450's Avatar
I could build that for about $50 or so . Might not be as pretty but it would work just as well lol!
Old 11-23-2013, 08:24 PM
LT1RAY's Avatar
This is my thinking as well. Maybe even offset it and use the factory torque arm location. Here's another one used in RX7 8.8 solid axle swap.
Old 12-11-2013, 07:09 PM
96lt1m6's Avatar
Super clean set up here
https://ls1tech.com/forums/gears-axl...8-project.html
Quick Reply: Mini ladder bars suck!!!! My new set up
