Ujoint install help
Old 11-17-2013, 06:28 PM
ENASNI TILLER's Avatar
Default Ujoint install help
I've installed quite a few ujoints in the past. The factory ones had nylon molded around the caps in the channel. I have removed all of that. But I have never seen this setup and cannot figure out how I am supposed to install the ujoint with the clip. If I put the clip on the cap it won't fit in the driveshaft hole. If I put the clip in the driveshaft the ujoint cap can't make it past the clip. Most ujoints have the clip on the outside but not these. Help hehe
Old 11-17-2013, 07:15 PM
S10xGN's Avatar
Assemble it first, then do the clips:
Old 11-17-2013, 07:27 PM
So the factory grooves are not for the new clips? That makes allot more sense. I was thinking I had to use the factory groove hehe.
Thanks!!
Old 11-18-2013, 01:03 AM
01ssreda4's Avatar
Assemble then clip. However it can still be a very tight fit. You may have to clip one side, then press on the joint a tad to get enough of the opposite groove exposed to get the adjacent clip in. They are generally a pain in the butt.
Old 11-18-2013, 11:45 AM
My car deffinetly didn't need them but since I have the driveshaft out I might as well swap them. I'm going to finish it up today.
Thanks for the help guys!
Quick Reply: Ujoint install help
