Quick Performance Fab 9" detailed photos inside........
I also got my qp fab9 a couple weeks ago 35spline wavetrac and also stripped out center bolts and had to redrill shock and pan hard holes. I hopefully have mine done within a couple weeks. otherwise so far so good. are you keeping 3 channel abs?
Ditching abs. I also have a local guy here who is an awesome 9" guy so getting a new nodular iron, all the most beefy stuff to handle 1000+ hard manual trans launches for $950.
What is your plan for a torque arm? Someone (might have been QP) said not to run an adjustable arm because their mounts are adjustable and you will end up breaking one or the other.
Very nice. I've been planning on doing a 9 inch this summer and have been trying to figure out where to get it from, and how to get to my house the easiest/cheapest way. I didnt even realize these guys were almost in my back yard! Looks like I'll either be stopping down there or calling them pretty soon.
Ill have install pictures soon guys. Dropped money off for my center section the other day.
New Nodular Iron case
Big Bearing Daytona pinion support
Full Spool
3:18 Gear
Chromoly big bearing caps
Also I ordered LCAs from Midwest Chassis. I should have all within the week and Ill post install pictures up. I am going with the high gear become since this thread was started I have sold all my 6speed stuff and going auto. Also pulled the engine out and all. Starting from scratch to build the car the way I want.
Full Spool
3:18 Gear
Got the rear installed last night. Rotors drilled out. Nothing adjusted or tight yet but its all in there. Even test fitted my wheels with the 5/8 studs. Race Stars will fit with 5/8 studs. Rear will have to be repainted in spots as well as a anti roll bar installed later on. Still gotta put my calipers on and brake lines.
Stock rotor vs drilled
#35
Now that I got the car sit down it looks like I installed a lift kit. Guess I'll be cutting the tunnel out for ta clearance when I do my cage.
