friction modifier
Old 04-09-2014, 08:14 AM
slowbird6.0's Avatar
Default friction modifier
okay guys need some help. I just change the fluid out of my 12 bolt Moser rear end as a auburn posi with 373 gears and 33 spline axles. I just put rial purple 75 90 gear lube. I still have a clunking no eyes only when I turn. Any suggestions if I should add friction modifier to it? Even tho royal purple has modifier in it already? Thanks guys.
Old 04-09-2014, 08:33 AM
thunderstruck507's Avatar
you will probably have to add some, the GM and Ford stuff being the best
Old 04-09-2014, 08:51 AM
Exeodus's Avatar
I would recommend it. Any dealer should have it.
Old 04-09-2014, 01:43 PM
Rob WS6's Avatar
Yup, youll need to add the posi additive. $13 at a gm dealer, just bought two bottles a couple weeks ago. One bottle should be fine for you.
Old 04-18-2014, 08:19 PM
joecar's Avatar
Read your bottle of Royal Purple gear lube, it already contains friction modifier (it says "friction modifier" or "limited slip" or "LS").
Old 04-19-2014, 09:54 PM
cgormanZ28's Avatar
Put some FM in it and do some very tight figure 8's at slow speed.
Old 04-19-2014, 09:55 PM
cgormanZ28's Avatar
I have a Torsen and I'm running RP as well, I didn't have any abnormal
noises from mine. You have to be precise on the FM, don't add too much.
Old 04-19-2014, 10:12 PM
Chevyman1968's Avatar
This is what I asked Bob with brute Speed and this was his answer below.
Originally Posted by Chevyman1968
I ordered the Moser 12 bolt yesterday from you and I have a few questions. For the u-joint. Do I use the factory u-joint if not what u-joint will I need and how many quarts does the 12 bolt need? I would like to have all this ready upon delivery.
Thanks in advance Ernest Bourgeois
Gear Oil - It takes 3 quarts
The limited slip differential design has been extensively tested with high quality NON-Synthetic 80W90 hypoid oils ( regular mineral based oil ) treated with GM or Ford friction additives ( 3 oz. of additive will treat 1 quart of oil ). To avoid differential clutch chatter ( noise ) and for optimum performance, use the oil and additive described above. Use of other additive and oil types may cause differential clutch chatter.
GM Friction Additive # 1052358
Bob
Old 04-19-2014, 11:50 PM
cgormanZ28's Avatar
^ Perfect!
Old 04-19-2014, 11:52 PM
cgormanZ28's Avatar
I have a question that I have not been able to get a clear answer on,
maybe you guys can help. Does Torsen AND Auburn require a source of
friction modifier??? If not, which one does and which one doesn't and
why? Thanks in advance. Sorry to ask within this post.
Old 04-20-2014, 03:31 AM
joecar's Avatar
Friction modifier is for helping the friction components (clutches or cones) used in positraction style differentials to repeatedly grab/slip without shuddering.
Torsen has no clutch/cone friction components, and so does not require friction modifier.
Quick Reply: friction modifier
