Another 10 bolt bites the dust >:(
So now I'm on my second 10bolt or was on my second 10 bolt. It went under normal driving situations shifting into 2nd under half throttle. This one was a rebuilt one when I got it. With 10k on the clock Posi and 4.11 gears. I put around 34k and it lasted 2 years. I'll probably save for a 9/12 bolt looking to spend under 2k. But this is my dd and I need to get to college and my job. So my question is I found two rears. One has 136k on it came out of an 1995 LT1 Auto with 3:23 gears for 200. Or two a 4.11 richmond geared posi with unknown mileage 300. I searched the forums and discovered that 3.23 gears put less strain on the rear? But with my current setup I could roast the tires easy from a second gear rolling punch with the 4.10s. Since I'm going to replace it should I just go for the cheaper stock rear?
OEM 3.23s' would be stronger than the 4.10s'.
Since it seems like you're eventually going to be a 9" or 12 bolt,what does it matter if you only have the 3.23s' for now ?
Since college and job are of utmost importance at this time,the 3.23s' will do.
3.23s'=stronger and save $100
4.10s'=weaker and spend an extra $100
The other thing your not mentioning is 3 or 4 channel , you need to match with what you have currently , if you have a sensor in the center section you have 3 channel , if you have sensors at both backing plates instead its 4 channel when looking at rear ends.
Sorry I don't know what channel it is but I will check. But yeah I want a year or two out of the rear. No track appearances or much street racing. I'll try and curb my driving style not that I drive like an *** but is a trans am you can only hold out for so long lol. But I think I'm going with a 12 bolt from Brute Speed. I'm only looking to make 400-520 rwhp on a H/C/I supercharged application
LS1Tech Sponsor
The info at this link may help you out. Let me know if you have any questions. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
http://shop.brutespeed.com/Brute-Spe...nformation.htm
