Best 60 Foot on Stock 7.5"?
Old 07-30-2014, 01:02 AM
  #41
-Op-'s Avatar
Little more RPM with a hint of clutch sliding
Old 07-30-2014, 03:07 AM
  #42
hrcslam's Avatar
Originally Posted by -Op-
2.001 on Nexen 3000s. 01 M6 WS6. Car was all stock except for a lid. Full weight car. Leaving around 2500, sliding the clutch out.
Originally Posted by badformulaLS1
My best is a crap 2.1. Only been out to the track once so I need seat time to get better at launching the car. Was doing clutch dumps varying rpm from 2500-3500 and the car would bog down hard and fall on it's face and then take off again. I don't know if it's maybe the tune or if I just need to slip the clutch or try launching at 4k+, but a 2.1 is where I'm at so far on Toyo TQ drag radials. Stock untouched rear with stock 3.42 gears.
Thanks guys, updated.
BadFormulaLS1, you have to roll on the throttle faster than releasing the clutch. I've learned to play with it until I can keep the RPM's at or above 4,500 RPMs while at full throttle and slipping the clutch. It stinks, but got me down to a 2.09x 60' on all seasons. I still need more practice though.
Old 07-30-2014, 09:56 AM
  #43
guppymech's Avatar
Originally Posted by hrcslam
UPDATE: Please provide the following info, 60' time, girdle or not, support bars, welded tubes, gear ratio, A4 or M6, and # of passes. Thanks Guys!
My best 60' with the 10 bolt on street tires was 2.004, car is a M6. The rear end had 4.10s, a solid spacer, TA girdle cover with ARP carrier cap studs and 23 passes over a few years. The Auburn posi finally wore out and rather than repair the 10 bolt I upgraded to a S60. I didn't see consistent 2.0x 60s until I went with 4.10 gears vs 3.42s.
Old 07-30-2014, 11:00 AM
  #44
hrcslam's Avatar
Thanks, Updated.
Old 07-30-2014, 11:11 AM
  #45
98CayenneT/A's Avatar
I also have a updated 60' time. 1.83 with 3.73 and yank 3600 on nt05r dr
Old 07-30-2014, 02:08 PM
  #46
hrcslam's Avatar
Thanks guys, updated all.
Old 07-30-2014, 02:51 PM
  #47
flintwrench69's Avatar
On the 10 bolt I only ran the nitto 555 DRs so might wanna change that! I did have it listed as MT DRs, only ran them with the 9 inch. My bad, its been a while since I ran a DR.
Old 07-30-2014, 09:20 PM
  #48
hrcslam's Avatar
Fixed, thanks!
Old 08-04-2014, 07:40 PM
  #49
Dan
Dan's Avatar
1.56 with Drag radials, built transmission with Yank SS4000, 3.42 gear(GM Posi & Ring & Pinion), no Girdle, no cover, no nothing..lol. It finally exploded 4 years later..I probably had 500 passes on this damn 10 bolt before it exploded. I can't complain
Old 08-04-2014, 08:59 PM
  #50
badformulaLS1's Avatar
Cutting good 60s with the auto seems to be a totally normal and common thing. Maybe we need a 6 speed specific thread lol.
Old 08-04-2014, 09:27 PM
  #51
NW Iowa WS6's Avatar
6speed here, broke my 10bolt with a 1.76 on nitto 305/35/18s. No catastrophe but whining loud after
Old 08-05-2014, 06:43 AM
  #52
01ssreda4's Avatar
Sumitomo 1.95
ET street radial 1.57
Old 08-10-2014, 12:05 PM
  #53
Marc 85Z28's Avatar
2000 Trans Am: 1.48 60'. 3700lbs, 3.73 Motives, Zexel-Torsen with LPW cover and solid pinion spacer, 4L60E. 10 years, ~25K miles, and ~20 passes.
1985 Camaro Z28 1.62 60'. 3500lbs, stock GM 3.42, Zexel-Torsen with LPW cover, welded tubes and bracing, 700R-4. Almost 15 years, ~100K miles and more passes than I can remember. This rear will see an additional 500hp this fall and I'm looking forward to low 1.4s
Old 08-10-2014, 05:10 PM
  #54
dailydriver's Avatar
The best I can remember is a 1.76, on a sticky/prepped Atco launch pad, with; Nitto DRs, Cartek clutch with Neo 610 brake fluid, AAM/GM 4.10s, Eaton cf Posi, Red Line 75W-140 with 4 oz, of Motorcraft XL-3 additive, full size (275/40-17) fronts, front sway bar attached, stock size rear bar, Driveshaft Shop 3.5" alloy shaft with 1350 yokes on both ends, and pretty much a road race suspension (LG valved, Bilstein coilovers, UMI double rod-ended, rear LCAs & PHB, Random Tech stock location, adjustable torque arm).
This was on the way to a 12.6 @114 mph with not even bolt on power (lid, 10% ud pulley, factory stock exhaust back to the y-pipe, SLP y-pipe and 2OTL cat back system, and FULL operational emissions still hooked up), BUT, the car is MUCH lighter than most of them on the road (~3250 wet, with no driver) due to it being a NO options hard top.
Old 08-10-2014, 10:53 PM
  #55
zzracer's Avatar
Default gears
Originally Posted by madmike9396
Sorry ! TA car and I want to say he had 323s at the time
3.90 gear and it broke the unit but he still drove it an hour to get home.
Old 08-13-2014, 05:02 PM
  #56
hrcslam's Avatar
Thanks added.
Right?! I may just have to split the list in to Auto and Manual lists. Or top and bottom, same thing. LOL.
I got yours already. Maybe from LS1LT1? Not sure. Thanks.
Originally Posted by 01ssreda4
Sumitomo 1.95
Need more info, Trans (A4 or M6), gears, tires, anything else you can provide like girdle, suppport bars, suspension, car weight, etc. I don't need all of it but gears, trans and tire at a minimum please. Thanks! That's a good 60' for a street tire though!
Thanks. How much did those support bars cost for you to weld on?
Thanks.
Thanks.
Thanks everyone, I updated the list in the first post.
Old 08-17-2014, 03:33 PM
  #57
blackLS1m6's Avatar
Original 10 bolt 3.23 gear no mods to it and it has a 194k. I've only replaced a few bearings thats it. Ive cut plenty of 1.6s on it with a best of 1.58. Probably has a good 50 launches on it and no noises. The 1.58 was a soft launch too
Old 08-17-2014, 04:02 PM
  #58
01ssreda4's Avatar
Stock weight, stock suspension, auto, 3.23 gear, full weight, no 10 bolts mods.
Old 08-17-2014, 08:37 PM
  #59
hrcslam's Avatar
Was that on Drag Radials, slicks, or street tires?
Thanks!
Updated list.
Old 08-20-2014, 10:56 AM
  #60
ybaslo1's Avatar
2001 Camaro Z28
115K miles - stock engine and transmission
Auto
ss4000 converter
Stock rear end out of a manual trans car > so it has a 3.42 gear
Rear end Girdle
M/T Street Radials on stock wheels
Also has a lid, some suspension components, full exhaust, and a 50 shot of nitrous (45 extra hp over n/a on the dyno)
Quick Reply: Best 60 Foot on Stock 7.5"?
