Best 60 Foot on Stock 7.5"?
Old 08-21-2014, 08:55 AM
  #61
hrcslam's Avatar
Originally Posted by ybaslo1
1.593
2001 Camaro Z28
115K miles - stock engine and transmission
Auto
ss4000 converter
Stock rear end out of a manual trans car > so it has a 3.42 gear
Rear end Girdle
M/T Street Radials on stock wheels
Also has a lid, some suspension components, full exhaust, and a 50 shot of nitrous (45 extra hp over n/a on the dyno)
Thanks, Updated.
Old 09-01-2014, 06:06 PM
  #62
73CamaroLT's Avatar
I did a 1.89 60" in a bolt-on M6 car. 245 Nitto 555r DR. with full rear suspension. Slipping the clutch at 3500rpm.
Old 09-01-2014, 09:04 PM
  #63
garygnu's Avatar
how long did those 7.5 rears last after the 1 good launch ? a 1.7 60 ft is great with these stock rears ,but frak a rear or U-joint ,and it can add up .
Old 09-01-2014, 09:35 PM
  #64
hrcslam's Avatar
Bolt On 2002 Camaro SS runs 12.7 @111mph - YouTube
Thanks, Added!
See the first post. It's listed with best without issue and worst with issues for both A4 and M6.
Some have gone hundreds off passes under 1.8 on the Auto. Manuals have no such luck. But, breaking an axle with a 60' time over 1.9 seconds seems to be the exception and not the rule. I'm sure technique can get an M6 to match an A4, but it would be difficult and likely would take more axles than the effort to nail it.
Old 09-02-2014, 08:19 AM
  #65
73CamaroLT's Avatar
Forgot to mention I'm on a 4.11 gear with a girdle. But other than that stock. I have zero plans of upgrading the rear at the moment. Im hoping to get the car mid to low 12's on that rear. I have 15x8 race stars I'm going to put a 275/60 nitro 555r on it and let it eat at the track lol. I have a few buddies with stock rears laying around so. lol.
Old 09-02-2014, 12:49 PM
  #66
hrcslam's Avatar
Thanks, updated!
Old 09-02-2014, 02:53 PM
  #67
gruntwork's Avatar
1.52 60' time, 100% stock 3.23 rear with ~92k, SS4000, 275/40/17 MT DR's, less than 20 passes in the low 1.50's, less than 50 total launches at the track. No noise yet.
Old 09-02-2014, 08:47 PM
  #68
jblankenship's Avatar
1.46, torsen diff, motive 3.73, solid pinion spacer, LPW ultimate girdle with braces, tubes not welded, 3500 race weight, 275/60/15 MTs, countless motor passes in the 1.5s, at least 15 passes in the 1.4s on nitrous progressed, times in sig.
Old 09-02-2014, 11:33 PM
  #69
hrcslam's Avatar
Thanks everyone. List Updated!
Looks like these rears stock can handle quite a bit of abuse especially behind the auto! Those Girdles seem to be worth every penny. Hitting Sub 1.5 60' and 10 seconds on the tiny 7.5" may be the exception, but with good parts absolutely possible.
Thanks guys!
Old 09-03-2014, 08:00 AM
  #70
Stardust's Avatar
Originally Posted by Stardust
My best is a 1.70 60' . Stock rear end, 3.23, 3400 stall converter. I did add Moser axles and a Moser girdle this year just for fun. Hopefully it gets me by for awhile.
Update, she's got a growl to it now. Low pitch, same noise on acceleration or coasting. Hopefully it's just one of the axle bearing I got from Moser, easily replaceable.
Old 09-03-2014, 11:30 AM
  #71
Slow94Formula's Avatar
Do I get more points for getting mine to go 9.63 @ 144?
Old 09-03-2014, 12:23 PM
  #72
Sladester2's Avatar
1.9 stock rear, bolt on 99 M6. No noise what so ever. BFG drag radials
Old 09-03-2014, 03:01 PM
  #73
hrcslam's Avatar
Thanks, updated.
Someone give this man a cookie! That's good news for those that want to stick with GM's stock offering. 9's is certainly an exeption, but 12's maybe even 11's are absolutely possible on the stock unit.
Thanks, added.
Old 09-03-2014, 05:31 PM
  #74
dailydriver's Avatar
Yes, and is TOTALLY contrary to those who claim that these HAVE TO grenade on the very first launch on street tires, pure stock power levels, greasy track, or even on the street.
Old 09-11-2014, 08:27 PM
  #75
1FineSS's Avatar
Default 60ft
Automatic 4l60e, 3200 stall, stock rear end (3.23 gears) with 26k miles, 100+ passes, and a best of 1.743
Old 09-14-2014, 09:21 PM
  #76
hrcslam's Avatar
Thanks, Added!
Old 10-12-2014, 07:55 AM
  #77
madmike9396's Avatar
my friend is JonCR96z
here is his best 60
1.469 - 60'
4.451 - 330'
7.047 - 1/8
95.44 - MPH
Old 10-12-2014, 09:53 AM
  #78
98CayenneT/A's Avatar
I'm already on the list but have a new 60' on the same set up
60' 1.758
Old 10-13-2014, 10:47 AM
  #79
maxpower_454's Avatar
I have to check my slips to see if I did any better but I know I've done st least a 1.86 60' on nitto 555r's with an M6 and 4.10's. Plenty of 1.8XX 60' passes tho.
Old 10-16-2014, 10:10 AM
  #80
hrcslam's Avatar
here is his best 60
1.469 - 60'
4.451 - 330'
7.047 - 1/8
95.44 - MPH
Thanks, updated.
60' 1.758
Thanks, Updated.
Thanks, Added.
Quick Reply: Best 60 Foot on Stock 7.5"?
