Different from 3 channel and 4 channel
Old 07-02-2014, 06:01 AM
KENS WS6's Avatar
Default Different from 3 channel and 4 channel
What's the dif. I have a strange 12 with 4.30 gears and abs and traction control
Old 07-02-2014, 11:44 AM
cyberkill's Avatar
I don't know about the strange 12, but I'm speaking from a stock 10 bolt.
3 channel means you have just ABS
4 channel means you have ABS and Traction Control.
In both systems, your front wheels have speed sensors. In a 4 channel, you'll have a speed sensor behind each of the rear wheels (a sensor at each of the 4 wheels = 4 channel). The axles themselves have a reluctor ring - look at the "With TCS" in this pic.
In a 3 channel, the rear axles don't have the reluctor ring, but the reluctor ring sits on the ring gear inside the diff (check the pic below). There's a speed sensor mounted to the top of the differential. You can kind of see it in this pic. It's the little black thing on the top of the housing.
Quick Reply: Different from 3 channel and 4 channel
