10 bolt axle shaft spacer orientation question
Old 07-22-2014, 03:37 PM
FNSlow's Avatar
Default 10 bolt axle shaft spacer orientation question
I had to an axle to replace a wheel stud. I didn't pay attention to the orientation of the spacer between the axle shafts in the differential. It has angled slots that i assume push oil toward the center of the gears in the forward direction but I want to be sure before I put it back together. None of the repair parts sheets that I can find show this part.
Old 07-22-2014, 09:09 PM
01ssreda4's Avatar
I've run it both ways with no issue.
Quick Reply: 10 bolt axle shaft spacer orientation question
