Rear axles ?????????
Question I had my rear end rebuilt 10 bolt with 3.42 gears in it and i had front and rear disc brakes put on at the same time with my new rims and tires I drove it and i'm getting a bad vibration in the front but i have had my front end rebuilt new everything and i had the tires rebalance twice and a friend of mines said it could be my rear end could that be true what do you think are could something be out of balance or did i get f@#$% !
Anything is possible, can you describe if the vibe is rpm or speed dependent? What all in the car vibrates? What changed right before the vibe started?
Drum Spindles
Can drum spindles make your car shake if there bad and can they go bad? I'm trying to brake down this shaking that I get when I get up to 60 mph then smooth out after I hit 75 mph I didn't get this till I had my front and rear suspensio done and brakes, shocks and rear end rebuilt and they guy put drum spindles on my car wondering if that could be it any ideas?
