Strange 12 bolt Ring & pinion wear pattern help!?!?!?!
Old 08-03-2014, 09:42 AM
hp275's Avatar
Default Strange 12 bolt Ring & pinion wear pattern help!?!?!?!
I am Currently in the process of redoing the Strange 12 bolt on my 2000 Camaro SS.
I bought the car with the rearend and 4.11 gears already installed but had a highway whine that was unbearable.
So I decided to install a new set of 4.11 gears/rest backlash and need some input on the ring wear pattern. (Parts Include: All new bearings and new U.S. Strange gear set)
My first step was to use the .027" shims that were on the old pinion gear for a good starting point and with .010" backlash but my ring gear wear pattern was way off.
Since then I have been fighting it and can get a good wear pattern!!!
I am all the way down to
.017" on the pinion shim thickness
I have 22 in lbs spinning resistance on the pinion gear w/ a solid preload tool.
Backlash is set at .010" (Strange's specs .008-.012")
My coast side looks great, but my drive side has a goofy mountain pattern
Going from a few instructional diagrams they say the pinion shims should be removed...
Agree or disagree? .017" just seems like a huge difference from the original .027" pinion shim thickness.
Old 08-03-2014, 10:44 AM
guppymech's Avatar
Looks to me that the pattern is too high on the tooth. Do you have any pics with the .027 shim?
Old 08-03-2014, 10:53 AM
01ssreda4's Avatar
Take some backlash out. Shoot for 08. Then show us the new pattern. Remember to hold resistance on the ring as you spin the pinion for your pattern.
Old 08-03-2014, 03:54 PM
hp275's Avatar
I didnt take any pics of the ring gear wear pattern with the .027" shims.
I will try the tighter backlash, and the pics are with resistance on the ring gear while I spin the yoke.
Thanks for the input.
Quick Reply: Strange 12 bolt Ring & pinion wear pattern help!?!?!?!
