My Moser 9 is leaking from axles. Need major help
Hello all.
I really need some help. I've done some looking online and came up with something but I just want to make sure im getting right stuff. My studs snapped off of my Moser 9 today. Really pissed about that. Well come to find out both of my axle seals appear to be leaking from all the oil covering my breaks and wheel wells. Not to happy cause the rear is about 2 years old, Maybe 2 1/2. I don't want to start ordering seals and bearings. I didn't assembly my rear my buddy did. So i'm not sure what bearings it had. Its not to old so someone who assembled a rear recently can help me out. BOB?? So if someone can help me out please chime in. Ill attempt to do this myself if I have the right seals. Thanks guys. Ill post pics tomorrow and I know for sure its coming from the seals. please help
Thanks
Thanks
I like the taper bearings/seals and conventional dyno lube. Syn leaks and makes more noise imo but it does last a lot longer. With the cheapy dyno lube a seasonal change is wise and good for inspection anyways. Also dont over fill the diff, this will lead to leaks no matter what lube you run. Axle seals will not withstand an oil bath.
Tapered bearing have the seal built into them. Ball bearing don't, they require a separate seal.
First off you need to determine which type of bearing you have.
Vent can be just about anywhere. It should be on an axel tube. Vents on the differential tend to get lube tossed out them by the ring gear. Vent is normally a nipple 1/2-1 inch long 1/4" diameter.
Taper bearing the seal is stand alone. Roller bearing the o-ring seal thing is part of the bearing.
Heres a 9" style taper bearing and seal
Heres a roller bearing and o-ring type seal; Obviously the o-ring goes in the groove. These are more prone to failure and leaking in my experience
LS1Tech Sponsor
It is quite common for the wheel bearings supplied from Moser to not have an o ring. In this case you use silicone sealer (RTV) around the outer edge of them prior to installing the axles into the housing.
Gear oil should be filled to the bottom of the hole shown in the above pic.
The vent is located on top of the driver side axle tube. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Premium Sponsor
The tapered bearing and ball bearing are NOT a direct swap.
Most Moser axles will come with a 1.531 axle shaft and a ball bearing, and will NOT accept a tapered style bearing which is much better for street use. When we setup rearends for customers they always have the larger diameter axle shaft and tapered bearing unless it is a race only purpose car.
I stand corrected sorta.... some of the roller bearings have the same 1.562" id and some have 1.531" id. First Ive seen that ( i had to search it out ). Ive swapped from roller to taper before
Yet another reason for anyone who views this thread to go taper from the get go. There is no downside to them, only plus
I have never been able to find the correct ones for a swap.
I must have got lucky? Anyways Moser lists two roller bearings
PN 9508B roller 1.531" Id
and
PN 9508T roller 1.562" id
both 3.150"od
I wonder why the different sizes? FWIW I have minimal roller experience. In the early days we ran c-clip elims and I had all sorts of bearing issues and skipped straight to taper when I got diff savvy. I always recommend them but have a couple buddies who cheaped out and went roller which I advised wasnt a big deal because "can always upgrade later..."
Now? Im not so certain i gave sound advice as you dont really eyeball that difference so I have no clue if they got the smaller ones or not oh well, lets just hope they dont run into issues down the road and make me feel worse.
Go figure, i step in this thread to help out and I end up getting helped out too
and
both 3.150"od
and
both 3.150"od
and
both 3.150"od
IMO I appreciate it because that's how we learn and I know I need the help.
You have to order the axels for either roller or tapered.
You cannot swap from one bearing to the other due to the difference in inner diameter. There is no difference in the housing ends only the axel diameter.
You have to order new axels with desired bearings.
