10 bolt what brand diff and gears
I HAVE 2002 Z28 AUTO WITH 3:42 GEARS AND STOCK DIFF. It is looking like I broke a tooth off one of the gears. Probably going to replace the diff and gears. Not sure what to get. I have Yukon gears that only had a 1 year warranty. A friend told me to go with Anburn Pro another said a detroit locker. Any thoughts?
A trutrac and a motive gear would be what I would choose. I've had good luck with the stock torsen diffs so I wouldn't be so quick to dismiss it, especially behind an auto trans.
No unfourtunatly. But dont listen to people like him, I've got so many ten bolts out there getting the crap beat out of them and not breaking. A properly built ten bolt is not a bad rear end, and can go pretty fast behind an auto without a hiccup. I've got some holding abuse behind m6s too.
I am only at 400hp with what is done to my car I have got one good idea for my cheap budget. Does anyone else have a good path for me to take? Thanks for the help.
The Truetrac is definitely stronger than the stock Torsen T-2, but not much more bias than the stocker, sadly enough.
The Eaton Posi, although a different type of diff than the two above, is also very strong, and has more bias than both of them.
Is your car a A4 or M6? If it's a A4 then I guess you'll be ok with the 10 bolt like ssred said. I second the recommendation of a Eaton Truetrac. I had a Auburn that wore out in a 10 bolt that I unfortunately put money in....fool me once...not twice, went with a S60 and didn't look back.
Finley got the cover off the diff. It is in bad shape. The Yukon gears did not hold up very long about 6000 miles. I think it will be motive gears this time.
With my ATI D1 at only 10 lbs I have 565 to the rear wheel with a Yank 3450 blower stall and Performabilt Level III. So far holding up well.
https://www.flickr.com/photos/183593...7630765750292/
https://www.flickr.com/photos/183593...57623345499537
