Axle bearing clicking when turning?
I hear a rotational clicking sound when turning right only. I hear it at just about any speed but I need to be turning enough. I thought it was coming from the front, but the more I listened and put my head out the window, it sounds like its coming from the driver rear...LR. Even lightly holding the brake pedal while turning, it'll still make noise. Is this the axle bearing causing this problem?
I think I've solved my issue. I replaced my rear brake pads with some quality ceramic ones and the sound went away. I had replaced the rear pads around the same time as the axle swap with some Autozone ones. I greased all the pins and replaced all the hardware then so that wasn't the issue. Simply changing the pads fixed everything. I'm not sure how or why but life is good now.
