proper u-joint for this setup
Old 01-21-2015, 02:34 PM
blue02z's Avatar
Default proper u-joint for this setup
hey guys, been a long while since I've posted here. but heres my deal. 2002 z28 m6. i have a custom built rear end housing from a guy named josh townsend it seems like its going to be solid as hell. its a ford 8.8 thats adapted to use our torque arm mount and uses the factory axle tubes.
my question is once i set it up i can get an 8.8 yolk from summit. they are built for a 1350 u-joint. will a factory style u-joint bolt up to a 1350 yolk?
thanks,
aj
Old 01-22-2015, 08:40 AM
Jtm2085's Avatar
I believe you need a bastard u-joint. Napa pn 447
Old 02-04-2015, 10:18 PM
blue02z's Avatar
thanks man! how sure are you that this will fit both a 1350 yolk to a factory ls1 driveshaft?
Old 02-04-2015, 10:33 PM
redbird555's Avatar
hes right.. its a pretty common joint combo. 1350 to saginaw 44 which is what the stock ds is. better measure though and make sure the factory driveshaft will work for you though.
http://www.napaonline.com/Catalog/Ca...447_0010270151
Old 02-04-2015, 10:41 PM
01ssreda4's Avatar
We always asked for the 1310 to 1350 conversion joint and it worked.
Old 02-07-2015, 06:47 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Keep in mind the factory drive shaft is very weak. When they break they usually flail around under there and take out the exhaust too. When mine broke it put holes in the floor. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 02-07-2015, 02:29 PM
JRENIGAR's Avatar
Im 100% sure it will work. I just used one like this. Oriley auto parts carries the Precision unit with the same 447 part #. I posted a thread in the auto trans section about this to help someone out.
Old 02-14-2015, 10:44 PM
blue02z's Avatar
Flippin A! Thanks a lot man.
Thanks to everyone and their input. I've got a driveshaft safety loop so if she breaks it should catch her. I'm also just bolt ons right now. Build is starting probably next month. Then I'll go with a new prop shaft
Quick Reply: proper u-joint for this setup
